G40 engine or not G40 engine
Right bought a conversion
And to cut long story short
I have some people telling me its not a G40 engine
and others saying it is
Tried to get a couple of pics of some numbers if someone could shed some light on this
Edited by DougyG40
  • Replies 79
  • Views 6.3k
erm don't think so came from Birmingham
so you think some one has replaced the lump with just a normal polo engine? what does it drive like?
well its looks like a g40 engine but wether the block is a py or not can't tell. the part number 030...... G where abouts is that?
tbh I don't know what has gone on but someone somewhere is telling porkies
and i want to get to the bottom of it
Well runs a bit shit bit like a misfire but wiring loom looks a bit pikey so could be that
Charger has just had a service so can't really boot it but seems to be a lack of power
Spaniel
030 is the number on the head
I can't tell if it says PY or not its hard to get a picture
The knock sensor is not plugged in as someone told me it is not present on the car but i couldn't see
Edited by DougyG40
could the engine number not tell you if its a original G40 lump?
Hoping someone will tell me this lol
Spaniel
thought so. well if there isnt a knock sensor plug on the back then it cant be can it. clean that number up on the side of the block next to the bell housing.
031100103AX thats the number I'm getting off etka for the py block.
to be honest I'm not 100% where the number should be though.
lol cheers spaniel
The number above the gearbox is very hard to see and hard to get a picture of
Is there anywhere else I can get a number from before i start taking inlet off to look at knock sensor
tain - Don't think so mate which I can proove with pictures from both engine bays
Mine did not have wires chopped off and loads of spade connectors
1. Thats nothing to do with you
2. Thats nothing to do with this topic
3. Stop trying to cause shit
Wondered how long it would be before someone started going on about that
Edited by DougyG40
lol cheers spaniel
while your at it clean the top flat area of the gearbox and check for the ATV might as well see thats right while your at it.
you should be able check fot the knock sensor by jacking the car up and getting under neath i think and having a quick butchers.
yeah was being a nice person but oh well hey ??? does it look like that face over there <<<<< cares?? i'll stay out of it
Edited by tainmrk3polo
if you dont already know the top bit being the flat area that touches the side of the block.
Ye will do someone has mentioned the gearbox is another mystery
if it's where the engine number is on my 1.3 MH engine, it should be on the front of the block on the top left corner where the alternator mount bolts on, i only noticed mine when i had taken the head off tho.
not sure if it would be the same on the PY tho...
Mate your comment was nothing to do with this topic
Got nothing constructive to say then don't post on my topics simple as
dougy get outside! i wanna know if its right. :lol:
its up at a garage
Spaniel whilst you got Etka open lol
Can you see what the cut off point for the mk2 g40 engine is please
well i recon its a mk2 g40 block, would explain things if no knock sensor...
and PY005xxxx does seem low, and mine is PY007xxxxx
hmmm
I'm going for PY005761
so etka that number...
its up at a garage
ah mate I'm just using vagcat i dont know how to do that. sorry.
well the block says says *PY 005781* or 61
which = G40 to be sure put a bit of white paper over it and rub it with a pencil :nod:
think someones pulling you are leg. not sure on the head number. but the blocks G40 anyway
think its a mk2 block2 with a mk3 charger usual vw use up the old bits till they run out. 005 is a low number mines 009 and its out a 1991/2 car.
Edited by genesisGT
i think it looks like its missing a bolt out of the bell housing into the block? unless the block is different and there is no hole.
