wiring loom Mk 2
Hi Well the indicator stalk has been replaced but the indicator light glows sometimes. fixed by pulling the loom below the sterring column towards me. BUT the main light switch {not Stalk} glows green on sidelight but the headlights are on as well but much reduced, when i ask for headlights the green light goes out. In addition once or twice the battery seems to die after turning the encine a couple of times {new batt. alternator gives out 13.9 amps} any clues Love the car its a 1990 gt coupe
  • Views 863
. BUT the main light switch {not Stalk} glows green on sidelight but the headlights are on as well but much reduced, when i ask for headlights the green light goes out ..snip...a 1990 gt coupe
dim/dip lighting became a legal requirement from 1989
legalese
Works as designed.
As for the battery, in very cold weather you should be able to crank the engine 5 or more times with a new battery, so long as it's not been drained by lights/radio/alarm/fridge box/GPS satnav/heated seats/DVD player or any other mod con added as an extra.
Starter motor? or a relay or earth straps.
Edited by dvderlm
