Mk4 Front Indicators
How do I remove my front indicators on my MK4 to cahnge the bulbs?
  • Views 974
What the one's on the wing or Headlight?
On the headlight. The indicators are seperate from the headlight
Hmmm I cant remember if you can do it witout unscrewing the unit. Pull the bulb holder out (i think u twist it 1st) change the bulb n put it back!!
IIRC all you have to do is undo the T25 torx screw on top of the indicator, and you can just pull the indicator unit out.
Its only the main headlight that you have to take off the upper and lower grilles, you have to take the indicator out first.
