New shell or not?
In summer I will hopefully be renting a house with a long driveway and a garage. ideal.
I have major plans for my polo, which I will definitly carry through because it just makes sense to do so. I'm a student so don't have much money other than living, but in summer I have a decent job so can modify the car and then keep it as it is over winter/spring when I don't have much money. Unlike getting a new car where I would have to pay x amount every month, or getting something like a G40 or a mk2 golf gti where insurance would just be too much.
Looking at the car now its just a 96 1.4l. No power steering or anything of the sort, which I like.
The bodywork isn't the greatest, rear arches both scabby, drainage holes have rust around them, drivers door has that patch that every polo seems to have, and I sprayed the driver door myself but the rust is slowly coming back after about 1 and a half years.
In your guys opinions, would it be worth selling and getting a new shell? I was thinking a very low milage flash red 1.0l with a view to a home brew engine conversion as I have access to solidworks and the rest.
Anyone else had a car resprayed with similar rust problems and had any signs of the rust coming back?
Might also add that the car has done 102k but the engine is amazing, no problems whatsoever.
  • Views 1.2k
thats voltswagon thinking :-D
I primed the bit after the drivers door where the bump strips are, as the water drips down from the window into the bump strip and made a big rust patch! A year later it was back, I didn't tend to it this time.
Before you go thinking about other things you want to do remember you have a sound car....
starting with a low spec model isn't always a good thing though, as you'll probably end up having to spend more fitting a better interior/electric bits/brakes etc than you would if you got a higher spec model
I suppose the proper way of doing it would be new doors, boot and get the arches cut out and new metal welded in. :cry:
I think I prefer no power steering, keep fit windows and a blower rather than air con! My thinking is stripped out interior, flocked dash etc.
if you are thinking of doing a project where you will be doing a lot of archwork and body mods then it is fine to carry on with what you have, but if you get a cheap base with nice bodywork as a starting point you will avoid spending a hell of a lot in the paint shop, where i'm sure most people spend the majority of their budget
also i would suggest as low milage as possible as it sounds like it may be a long term project, you don't wanna come out the other end with a car that owes you thousands and has done 200k
best thing in my opinion, go on ebay and wait for a nice low milage un-molested base model polo, as you say 1.0l, and snap it up, they don't make mega money and is always gonna have been driven carefully, then get strippin and flocking, the more stripped the less you will have to worry about getting dirty, broken etc.
then an engine swap later in life will give you a nice racey little polo, basic and fun !
Same wavelength Tom!
If its a really cheap low mileage 1.0 I might get it and keep it off the road, and keep the one I have as well
Edited by JonDog
I'm deffinately with Tom Garrett (welcome back BTW matey :thumbsup: ).
There are enough decent mk4 base models out there if you are gonna build something a bit special. Why spend time and money on new doors, arches, boot and a respay etc if you can buy something much better? You can bet there will be rust in your shell which would need fixing too once you start to take it apart.
Get rid mate and get yourself something better.
