De-Badging
Hi, I have just finished debadging my MK5. I removed the "polo" lettering with hot water and a credit card. Then I used Autoglym Intensive Tar Remover before t-cutting with colour fast t-cut. However I still have an outline of the lettering on the car. I was just wondering how to get rid of this? Will it just fade away with time? Or shall I get the tar remover and/or t-cut out again? Any help will be much appreciated. Thanks
  • Views 1.5k
Pop into your local bodyshop and ask them to run a mop over your boot lid quickly, unless of course you have a mop? This is what I used to do in my valting days when removing GB stickers etc
I've got the same problem any more ideas
I just ended up using more t cut and loads of force, and it's perfectly fine now.
thanks for this... many people have been asking this question at the mo... i will review what mine looks like tomorrow and tell you how good the lazy bastard method of just leaving it did... otherwise il have a go with your method indy!
thanks
I used that colour match polish. Worked a treat!
If you soak it overnight with WD40 it should come off lifting it with plastic card; that way you wont have to resort to T-cut or thinners.
