well it doesnt get much more anal than this......
well had my G40 in for an MOT at VW cos it was pretty much the only place that would do it at this crazy time of year. Anyway it failed on excessive corrosion on the two brake pipes at the front attached to the flexi hoses. I thought it was a bit OTT to be fair but can't really argue with the tester.
Anyway stressed over the fact that i'd now have to remove the original green pipes and have shit looking copper ones........ until i found out you can buy the original stuff!!
not cheap for a 5 metre roll i must admit but who cares. OVER THE TOP by far to keep things original but hey!
Edited by supercharged spaniel
  • Replies 44
  • Views 3.4k
hahah you big OEM HO! :D
So thats why we crashed :evil::lol:
How much was it?
Put it on ebay now
Rare G40 discontinued mega rare original green brake hose, this is hard to get hold of now, and just what you need for that true OEM look!
How much was it?
ha ha! it must of been!!
its about 4.90 a metre but i got it cost price. so it cost me about 18 quid for the 5 metres. not too bad i suppose.
ah so you went for the original stuff that will corrode, over the copper stuff which never corrodes. lol, that's the same as having sex with a special needs child because she's pretty.
Put it on ebay now
i could couldn't i? lol shame there is actually 102 rolls at the uk warehouse according to the system when i went in :lol:
what you talking about?? the original stuff has lasted 15 years nearly. your talking about the rubbish they put on the new polos. and the copper shit is even worse!!
and! all the others are totally mint? so what ARE you talking about?
Copper stuff is the best, as it will not corrode. The standard steel pipes are more likely to corrode. Also due to the copper being malleable, it'll withstand bumps and knocks better than the brittle steel pipes.
Will the DIY type flaring tools be able to cope with working the harder steel pipes into a flare? :?
Copper being soft, this is a doddle, but the steel lines?
thats utter shit mate. on my previous polo i constantly had to have the pipes replaced almost very MOT. down at the garage today actually talking about it they are forever changing copper pipes on cars. withstand knocks and bumps better :lol::lol: oh my god tell me more....
Reading about these DIY Tools on ebay and the likes, it appears the steel is too hard for them and a hydraulic press is best used to flare the steel pipes.
yeah we had a go. worked fine mate.
Well you did have that problem last year with tiny elves with tiny hammers in your engine bay...if they come back you'll tank your lucky stars you went for copper.
Edited by Tav
Take a 10 yr old steel pipe and a 10 yr old copper pipe, the copper is more likely to bend/crush whereas the steel will crack/fracture. if faced with one of the two in my braking system, i'd take the bent pipe any day!
the flaring tool they use works fine. its obviously harder to flare the steel but it works. they often have to re-flare oem steel ones to put new sections in on cars, so it can be done.
didn't realise you were getting a garage to do them for you Dan, they'll have the proper gear.
well how come all the rest of the system looks brand new? all the way under the car. its only the very ends where its exposed in the wheel arch that after 15 YEARS has become pitted? the proof is in the pudding my friend. whereas the copper pipe will have died after 5 years never mind 10.
dont mind doing pads and discs and stuff but i want these doing mint and would rather pay to have the whole system bled properly and the new pipes bent by people who do it every day.
copper still corrodes panda you spaz. ever seen a copper roof turn green? thats coz copper oxidizes. you can get some stuff called Kunifer which is Cupro-nickel alloy brake pipe which doesn't corrode like copper.
anyway, in this case it doesn't really matter, like dan says they have lasted 15yrs so far
could have been replaced by the previous owner for all you know.
Steel rusts, copper does not. FACT
copper does rust though. its like aluminium that rusts too. there are differnet kinds of rust. white rust etc.. ok. this could go on forever. lets just pretend they were replaced every year by the previous owner.
LOL
the "copper" ones you're referring to are steel with a copper coating anyways. just protects the steel from corrosion afaik.
