well it doesnt get much more anal than this......
The OE steel ones are plastic coated, so should last the test of time unless chipped or twatted with tools.
  • Replies 44
  • Views 3.4k
could have been replaced by the previous owner for all you know.
Steel rusts, copper does not. FACT
copper does rust though. its like aluminium that rusts too. there are differnet kinds of rust. white rust etc.. ok. this could go on forever. lets just pretend they were replaced every year by the previous owner.
Indeed, aluminium oxidises...acctually usefull as you can build up a layer of oxide to protect the part...called anodising.
You're a fool panda.
EXACTLY but i suppose plastic rusts? :-D :-) :-(:-o:shock::?8-):lol::x:-p:oops::cry::evil::badgrin::roll: :!: :?::|:arrow::idea:;):doubt::disgust: :p :angry::finger::nod::crybaby::retard::drool::ninja::puke::unibrow::paranoid::wasted::smirk:
:puke::puke::puke::puke: how i feel right now
Edited by supercharged spaniel
I've bought some of this to do mine with - gone back to the copper stuff as the steel was a pain in the arse to bend - there aint no second chances like you get with the copper ones!
just paint the copper lines green lol.
oh and get a brake line bender - or you'll crease the pipe when your shaping it
KiZ
Oh - n it is the biggest pain in the arse to flair them pipe!!! have to heat them up and work the metal of they split! BE WARNED
KiZ
cheers fella. well we have two pipe benders to use and a flaring tool. my mates who are gonna do it for me are confident about flaring the steel pipes as they sometimes have to cut out a rotten section and re-flare steel pipes to put a new section in. they are aware its much harder to do but managable just gotta take your time. should be easier off the car as they often do it still on the car when they're doing it this way and adding new sections.. time will tell anyways.
OVER THE TOP by far to keep things original but hey!
But it will be original.. which is what YOU want :-)
Good on you chap :thumbsup:
seconded :)
Dan ................... just make sure your brakes work thats the important aspect of this discussion. Be safe for 2008.
^^^^ :lol:
Took the words right out of my mouth lol
^^ HAHA.
god what a great day of posts weve had today! some proper random shit gone on today! a intresting way to start '08!
Edited by POLOMON
anyone tried copper nickel brake lines, should last longer than copper but is less flexible than copper, but easier to bend than steel
just to say. they flared fine, bent fine and look f**king spot on like new. and the resevoir was cleaned out and full new vw fluid through the whole system. standard brakes never felt so good.
Steel brake pipes are alot better in many ways. New cars are all built with steel pipes, as copper pipes are not strong enough for the ABS system, so they just split under pressure. Plus copper looks out of place on 'newer' cars like g40's, looks ok on old minis etc though.
Has it got fresh test on it now then?
tomorrow at 11
Sweeeeeet
Cunifer
