Mk3 Rear Brake Conversion
MODS - Please move this thread to brake section and clean up a bit too...
You need the rear brake kit off a mk2 golf gti i believe, though it also fits mk1 iirc. Possibly need different handbrake cables, though I'm not sure - someone could confirm this.
I intend to do this conversion in the very near future, so will write a how-to when its done. Looks to be pretty simple though. Please feel free to add relevant info for the use of others!
Pic of parts needed:
Edited by skatty_01
  • Views 858
sounds cheap to me, never seen any rear disc conversions though, is it an actual aftermarket kit or is it retro fitting other VAG stuff??
If everything is there and the discs and pads have plenty of life in them then it's not bad... Not cheap though
Bear in mind discs, pads and wheel bearings new will give you change from £40. I'm sure you could find a set of calipers and stub axles for less than £40 too...
No. £80 is VERY steep, I only paid £30 for a GTI rear beam with all those bits attached already. If everything was new and you needed them quickly it would be an OK price.
Yeah - remember, Mk2 Golf GTIs are ten a penny, and there are plenty in breakers!
think I've actually got a GTI rear beam in my back garden, will have a look once its light tommorow
and i dont think it should be closed and locked, put it in the braking section and rename it so we have this topic covered, then people can add to it with more info etc
