mk4 spoiler with brake light and mk5 rear lights
right has anyone had problems with their spoiler brake light after fitting mk5 rear lights?
basically i have noticed when i break and am indicating left the brake light flashes in time with the indicator as it goes off the other comes on...
now i understand this is because on the back of the bulb holder the little sockets i would plug the spoiler brake light ito are in a different location to the ones on the mk4 bulb holders!
other than that they work fine but obviously it isn't right...is there a way around it i have tried all combos of fitting the 2 wires into the available pin slots o the back of the bulb holders but nothing
will i have to hard-wire the wires into another location?
  • Replies 8
  • Views 1.7k
bet that send's roundabout's wild :unibrow:
i'd check that you don't have to re wire the spoiler light to work with the change in the wires of the mk5 rears
could be an earthing problem.
i think your right but which goes where :lol:
ermmmm i have no idea as i don't have a spolier!!
lol
i had this on mine... but with my stock 16v lights and the hella spoiler... was already in the car so had nothing to do with me
i moved the spoiler brake light earth from the left tail light to a bit of metal bodywork and it was fine
I did a mod on my rear lights from stock 1996 one's to post 1999 ones. The problem i had then was my brake lights were indicating and my indicators were braking (so to speak). I got two new wiring plugs from vw opened up the old plug with a small cutting disc and replaced the wires in the new plug but had to change two wires around. problem solved and been fine ever since. Although i will have to buy rear lights from an X reg onwards if i damage mine because mine are after market ones from ebay from the farterland £ 23 +p & p.
i aint changing any wires back again.
I found the wiring change by looking at my 1996 wiring loom and next doors x reg wiring loom.....spot the difference time.......Oh i had to buy new bulb holders from an x reg for this mod, cos the 6n ones wont fit, don't need the sticking out indicator part. New bulb holder everythings in line top to bottom.
all you had to do for that buddy was swap two wires around.
