german num plates but gb ones
basically what is the low down on these I've read so much about them. i want to order some form ebay now as pressed paltes look alot better, but do you get pulled oveer? even if there a gb one?
cheers :thumbsup:
  • Replies 12
  • Views 1.2k
yep.....
why though?
Illegal mate. Not allowed metal or different fonts. Whether you get pulled over for them is a different matter al together. Some get away with it for months, i was pulled within 5 minutes of setting off. What I tend to do is run standard plates in wolfsburg holders, stil looks pretty good. But for photos and meets etc I will use my german plates. Not worth the risk running german ones considerin you can get 3 points and a 30.00 fine per plate. I was lucky, however, and just got told to take them off. The whole thing with leaving your originals in your boot and running german plates is a load of rubbish IMO. Because whether the originals are in your boot or not, you still have to put up with the hassle of being pulled, and then answer a load of questions, and then you risk the police finding something else wrong with your car incase they decide to check it over.
sum of em arnt reflective, mine arnt and I've been pulled a few time but note been fined,
I've given up with pressd plates, they do look good..but can b asssed with the hassle form the police all the time
so what u using just normal uk plain ones now matey?? :paranoid:
why though?
By banning custom fonts, it stops people choosing fonts which are barely readable due to italics, small letters etc. Most will say that german plates are easy to read but it is very subjective, and which custom fonts are acceptable and which are not? So the easy thing to do is to ban them all?
They also don't want people using illegal fonts to dodge cameras etc.
The metal plates only reflect because they are metal, therefore they don't reflect enough. The plastic ones are made of a special material which makes them extremely reflective. Think thats kinda right?
u can get metal ones which are and arnt i think
I never got spoken to about my uk font pressed plates, got stopped a few times aswell. It even passed the MOT with them :thumbsup:
So i recon it depends on where you are whether you`ll get hassle from the police :ninja:
Pic showing the plate
mine went throw mot 2, think it just depends on the copper sum r ok sum ar k***s
The main thing that the cops appear to be focussing on at the moment is the font and spacing, because that's what causes the most problems for the ANPR cameras. A guy in my street has suddenly changed his plates for correctly spaced ones, so I think he's probably been pulled, and my hairdresser got pulled for script italic font (although I did warn her :paranoid: )
Technically, if you look at the BS kitemark on standard plates, and then go and look up the relevant British Standard criteria, it probably does state all kinds of requirements, including materials they must be made of, and levels of reflectivity, as well as the font and spacing. However, in real life, if the ANPR camera can read them, and they look kosher from a reasonable distance, it is unlikely that it will attract the attention of the 5-0. However, you always run the risk that if the cops are suspicious of your car or driving, and they're looking for a reason to pull you over, then you're giving them a fairly easy one. And if, once pulled over, you start giving the cop some lip, then you're handing him an easy thing to get picky about.
