Cutting mk3 bumper for fogs
I've got a set of fogs to go into my front bumper. Am i best attacking the cutouts with a jigsaw? I'd wondered about using a solderingn iron to melt the plastic , not sure if that will work though. Failing that i could attempt it with a mates dremel, thou it will be a challenge.
For people who've already done it, hwo did you go about it? Thanks! For a mk3 btw...
  • Replies 13
  • Views 1.6k
To be honest I just did mine with a sharp stanley knife!
I cut the large section out leaving plenty of material for fettling, fitted the fogs to the car, fitted the bumper, and then used a combination of a coarse and fine file to remove the rest of the plastic and get it looking neat.
Took about an hour or so but I'm pretty pleased with the results.
jigsaw it, then trim with a very sharpe stanley knife
We did this...great care needed.
i tried it, but decided i was likely to mame myself! jigsaw all the way and dont forget goggles and an RCD
I did it with a sharp penknife too but a stanley would be a better choice looking back. As has been said cut less than you think you'll need and then trim to fit so you don't have a gaping hole if they don't fit exactly as you'd expect (mine didn't quite fit perfectly).
yeah we did it with a stanley knife then tidied up the edges with a file, was quite impressed with it haha
I used a stanley knife to but be carefull if you do
Dan
i drilled a hole in all 4 corners then sawed between them till the centre fell out then filed it to the right shape.
filing takes ages! :-(
When I had to cut my bumper for clearance for my horn, I heated the bumper up in front of a space heater for a while, and then cut through with a 16 TPI hacksaw :lol:
Stanley knife for me as well, but as said before take extra care, so easy to slip and mame yourself or the your bumper.
I've been told an hot soldering iron works well to melt the square out. Just take your time, if you've got some spare plastic try on that first and perfect your technique.
I've got a spare bumpre that i'll be attacking 1st hehe, cheers folks... Think i'll blowtorch it, then attack it with an angle grinder for shits and giggles... Or just warm it with a lamp then get the stanley knife out.
i was interested in doing this, is it possible to take the bumper off without jacking the car up ? i cant really jack it up where its parked nor do i have a suitable jack.
Yes no need to jack the car to remove the bumper.
