6n door cards
hi all, how do you femove the plastic door card and window winder on a mk4 3 door cheers
  • Views 861
took me a while to do
the window winder. where its stuck onto the door card slide the spacer behind the handle to release the retaining clip. the direction in which you push the spacer will vary .
plastic door card take of the door pin take of the handle cover unscrew the two screws, pull the door handle thing that you open the door with from stationary to outwards then pull the doorcard of from the bottom and should come of fairly easily.
hope thats understandable :D
thanks for that :thumbsup:
