spraying
I have a vintage tractor and basically it needs respraying, now i have all the kit (i.e. spray gun, air compressor, hoses and paint obviously)but i have no idea how to go about doing it, i have to say though it is in better condition than my polo :paranoid: so basically if anyone has any idea how to spray i would be greatful for any links, tips etc to get me going.
anyway heres a pic for ye
i know its not actually a car but i didnt know where to put this otherwise.
  • Replies 10
  • Views 1.4k
you need to flat it all back prime anywhere you go through the paint or that needs it, mask off the whole thing well then paint 2 - 3 coats then depending on the paint your using clear coat it as well
looks pretty good to me you spraying the chassis and engine or just the panels, got a a nice we 35 tucked away as my winter project looking a lot worse than this, what sort of paint are you using?
what is flatting? and I'm only doing the red panels, not sure what type of paint it is (was the only stuff they had in the massey dealership, the guy said to use it for spraying, and I've got a thinner as well) my uncle had a go at spraying it himself but the paint is too thin all over and has only had one coat, excluding primer, sadly though he died last year from cancer and never got to our finished project (was a project me and him were working on for around 2 years) so basically it just needs lights wiring in now and a respray of the red panels.
flatting is roughing it up so the paint can stick well
you also have to flat and polish it to a finish once it's painted
Nice looking machine :) I only see John Deers and Fords where I stay, Oh and the Jaguar combine.
Way too much sh^te getting spread about this time of year :?
Try and get a hold of the Haynes on bodywork repair, a good port of call. Then search the internet on Diy respraying, use the search option on here. Theres so much to learn from practicing(getting stuff wrong yourself) even stuff like cleaning your spray gun can be gone into such length not to mention safety. I wouldn't no where to start..
Bare metal needs etch primer, high build primer, rubbed down(flatted), more primer, rubbed down, guide(light) coat of colour, two coats of colour(with flatting inbetween). grades of sandpaper start from 280 grit (dry) to 1500 grit(wet). Sorry this is just an example of how you might achieve a finish...
If your paint needs just the same colour over the old (blow over) then you can get away with keying with scotch pads(dry) or say 800grit(wet) to create a key. then theres panel wipe, tack clothes then the ratio of thinners.... goes on and on
I'm still trying to figure it out.
Go for it and good luck
Cheers Dunc
yeah it only has the one coat of paint on it excluding primer but it was put on thinly so i need to put on a couple more coats to part of the bonnet and the rear wings
If you bought the paint from a massey dealer it will be synthetic, should only take 2 coats as it covers well.
Apply a half coat and then a full one after about 10-15 mins once its really tacky, put it on too wet and it will run.
You wont be able to polish it so the finish you get off the gun is the one you will be left with. If your not happy with your second coat leave it for about half an hour and give it another coat.
Edited by bndesigns
reds a low hiding colour ;)
contemplated spraying my self its apparantly tricky to actually do it well......true????
depends what your spraying what colour and what equipment your using
most of the difficult work is the prep work the spraying is quite straight forward as long as you take your time and have some isdea of what you need to do
