Water inside my door post
Hi everyone my mk3 is letting in water inside the car where the door post is by where the seatbelt goes behind the rear doorcard. It comes from behind the trim leading to the roof.
But I'm not sure if it comes from the roof or not?? But it has soaked the seatbelt mechanism and all the seatbelt.
it has a sunroof but all of the headlining is bone dry?? I'm puzzled could it be the door seals??
Any help would be much apreciated (sp)
Dan
  • Replies 8
  • Views 1.7k
Oh and i forgot to say that it has been parked on a steep drive for 2 weeks but would that make an differance??
Dan
drivers or passengers side?
is it a factory steel sliding or a pop top?
they can let in at the door seals if parked at funny angles. mine does if parked the wrong way!
also the factory sunroof can leak - it fills up then overfloes if one of the drain pipes are blocked. (easy to check) also your description matches where the rear sun roof pipe attaches.
might be worth removing the door seal and looking behind the headliner with a torch! the sunroof drain pipes can pop off too its just a bit of rubber.
also look at the rear window seals could be gettin in their if a bit of dirt is traped distorting the seal.
also if its the drivers side could be the panel behind the fuel tank (pray its not their!) see photo
Edited by genesisGT
Could be a leaking rear window seal? If it's been sat on a steep driveway facing downwards it could have been the only opportunity it's had to run in there.
Hi its on the drivers side but it is parked on a steep drive and the car is faceing up the hill. Could it be just seeping straight past the drain points on the sunroof because of the steep hill its on.
Because driving the car on a 200 mile journey in the pouring rain and the seat belt was dry???
Dan
Has anyone got any more ideas??
Dan
Dan
Hi mate, having exactly the same problem at the mo - had a quick check of the rear window seal - looks like water could get past that but think i'll check out the sunroof as well as that sounds promising. The door seal does not sound like the correct area to me.
Having a wet seatbelt is not the best!
If I figure out the leak, I'll let you know, please do the same!
Cheers,
Dave
  • 1 year later...
Did either of you find a solution (it's been a year since your last post so I would hope so! :-D )
I'm having the same problem at the moment. Factory fitted sunroof and wet seatbelt, plus condensation on the windscreen. Going to check the sunroof drains on Saturday.
  • 10 months later...
anyone ever sort or source these problems?
