How many cans of primer?
Right I've recieved my 16v bumper today but it needs sanding down and repainting to the colour of my car so i was just wondering how many can's of primer should i use and what colour gray or white as the top coat will be dragon green? and what grade wet & dry paper? thanks
you only need to prime where you go through the paint
if it's already all painted fine just flat it all back well and paint the other colour
use 400 to flat it then 2000 to flat the clear coat and then buff
if you go on rough with the paint use 1500 before you clear it
the bumper will need some filler here and there as its got a few deep scratches
well you only prime those areas no need to prime the whole thing
ok thanks
