Hiding boot lock - MK3
Hi, i want to hide the boot lock underneath where it is (in between the number plate lights). Any ideas on how to do it?
I've seen a car on here with it done but i cant find it now :(
Also, how would you go about fitting central locking to the boot? i have a kit for 4 doors. could i use 1 for the boot?
Cheers, Toby
  • Views 1.7k
There's a bit of a discussion and maybe what you want here, a bit about boot poppers too.
I also thought there was one done like you want too but can't find it either, was quite a while ago I remember seeing it.
Philj was selling smoothed boot plynths not so long ago.
IIRC a groupbuy (which we won't go into discussion about) of some cult society mk2 golf boot plynths happened a few years back and they allowed for the boot lock to be hidden under the handle at an angle using the existing lock effectively smoothing it off but keeping its use.
Not to sure how many people actually got there plynths due to manufacting/groupbuy issues but its a cult society item you'll probably want. Only downside is I've think they had ad fitment issues so may have to a be a homemade jobbie.
Edited by StueyB
mines plastic welded n colour coded lux good....just use a solonoid for the boot wired up to beneath the glove compartment... who need central locking then!!!!
as stuey said.^^^^^
i got one out the group buy the fitment was pants, so i sold it. make you are own or buy a different make one.
I would use a solenoid and just get rid of the lock..
Bit I'm having lock-less handles and central locking so if the battery went dead id be screwed. So i wanted to have the lock still there on the boot but out of view from scum. And then i can climb through the boot if needs be if the battery goes dead.
Cheers for the replys guys :)
I'm intrested in this aswell as i want to french my tailgate
