Fixing A False Floor
I am gettting rid of my bready for a hopefullly a coupe next. I would like it to be a bit of a show car, and was just wondering how do you fix a false floor donw in lpace of the rear seats??? and how do you stick the carpet to the flase floor, spray glue???
cheers joel
  • Views 1.5k
anyone???
As for the fixing i would think just bolt into the seat mounts and make it a good tight fit.
As for the carpet... carpet tape? or staple it?
Go ont gay-bay and get a proper spray glue as it works a treat and doesnt add weight to the install, i used it for my install and mines clad in leather. Just plenty of spray and a set of clamps to hold it in place while the glue dries fully worked a treat for me and its never come unstuck and its been done 8 months ! :thumbsup:
yeah heavy duty spray glue , they use it on carpets in houses to , very very sticky and messy tho
Contact adhesive works too.
cool, cheers lads. What do i do about fixing the wood? do i bolt it to owt???
At the front behind the front seats you should be able to bolt it down to the old seat fixing point, i did.
And a the back drill a couple of holes through the floor and bolt it down make sure you seal it after tho, with some underseal, so it dont rust and leak.
