Polo People, **EDIT** It failed
Well, its MOT day today 3:30pm the test begins
I have no idea what to expect but I'm hoping and crossing everything that the olop passes first time so I can get it on the road and begin the changes
This is worse than waiting to see the dentist :paranoid:
Edited by choppa7
  • Replies 21
  • Views 1.5k
The good thing is its only once a year so you will only have another 12 months to chill ..
Hopefully it passes with flying colours !
If its as clean as it looks in the pictures it should fly through.
I'm not 100% Sure on the brakes as its been mainly stood and only moved abuot for a couple of years, even if I knew what they were like I would still be worried, I'm a big girl lol
Polos are great, you press the pedal and it feels like nothings happening but you have to wait for the brake gremlin to wake up and switch a leaver that engages the pad.
The brakes are truely shocking though. Your may even be one without the servo assistance which makes them even worst. I remember driving my mk1 for the first time and it was down a steep hill following my dads 6 months old BMW. Pressed the pedal and nout happen, never have I felt so much terror in my life. LOL.
lol, thatnks for the warning mate, I doubt there'll be servo assist on them, oooh bugger
I'll have to change my driving style I think, last of the great late brakers wont cut it from now :grin:
There is no such thing as late braking on an early Polo. Just braking to late :lol:
Mk2 brakes are alright, they just need good brake fluid and a serious amount of conviction behind your right foot.
At one point I was lacking in free hours in the day and ended up paying a garage to change a driveshaft for me. I went to pick the car up and the mechanic was just getting out of the car having taken it for a test drive. He was as white as a sheet. The first thing he said to me was "WTF's wrong with your brakes? I just nearly ditched it!".
He didn't believe me until we put it on the rollers and I showed him how you use them.
The sole reason why i would not drive a Mk1-2 polo without a rear axel conversion is the pathetic servoless brakes .
I found the brakes on my mk3 with drumms on the bac were quite good when teamed with a decent set of tyres. The car was stripped out and light so sped up fairly quick and stopped alot quicker .
I dont see why people would think that the brakes on a Mk3 are crap at normal road speed . There obviously crap at 100Mph but then you wouldnt expect it to stop straight away then .
I didn't mind the brakes on my mk1 once I got used to them.
There not great by any means but when you know how to use them they are fine.
:badgrin: :badgrin:
Yea mine are fine but I've got used to them, vented discs helped brake fade. You have to just stamp damn hard on the pedal to make them work.
Just had the garage on the phone, failed on brake pipes, needs a new set, worst case scenario £200 which includes the MOT and £50 recovery so its not too bad I suppose, just the faff on of having to wait for parts and them to be fitted which should be another week
boooooooooooooooooo
loads of polo's seem to be failing on brake pipes atm....
Cause there oooold!
my polo failed on brake pipes in june, £60 to put it right.....
Cause there oooold!
point made....bet mine fail's on brakepipes.
think we should go get a group buy on OEM brakepipe like the stuff supercharged spaniel's got lol
best way to look at it is they won't need doing next year, it will just be something else !!
i love old cars,they keep you busy all year round :-(
Thats good news, maybe it wont be as bad as £200 then
Just wait and see, could be a pleasant surprise!
that statement couldnt be more true lol
they sense when youve not spent much money on them, or spent it on a mod instead of maintenance then they kill a wheel bearing or sumat
polo's revenge :evil:
I've went from a mk3 polo (l reg) to an 04 plate megane, first time i drove the megane i nearly did an endo when i pressed the brakes lol :D accustomed to stamping on the pedal lol
yeh they are getting to the age where they will be dying!! depends if copper pipes that corroded or just split the rubber hoses. rubber ones should be about £7 a side, or that whats i paid anyway, copper stuffs about £20 for 3.6m of it, or go to a garage and they will charge you that + probably 2hrs labour on the copper ones, or 30min/prob an hour for the sake of it for he rubber hoses.
