mk3 interior handles with no mirror adjustment
I'm sure i have seen them before, but might be making it up :paranoid: Where there is a blank over where the headlight adjustment is. If they are real does anyone have a part number?
  • Views 1.3k
I assume you mean mirror adjustment and ont headlight. LOL
They do exist cause I have a set somewhere, where they actually are is something else. But they do definitely exist and your not going mad or making it up :D
ETKA gives no part for this.
at a long shot - could you be thinking of mk1-mk2 door handles which have the mirrors which you manually adjust?
I've had about 2/3 sets out of mk3s down the yard.
I think mk2 handles might be different, I don't know. But mk1 interior handles are definitely different.
i know mk2 handles are different, If anyone has the part number or a really old version of etka that might have them on. Didnt some of the very early mk3s have the manually adjusting mirrors?
I've got a few sets tucked away in the garage that I've taken off early Mk3's..
Basically, from what I can gather the base models such as the Fox, Boulevard had manually adjusting mirrors. Obviously the GT/G40 all had internally adjustable ones, and so did most of the CL's (although I've seen a few without).
I think from 1992 onwards all Polo's got internally adjustable mirrors as standard, so the handles with the blanks built in are a bit of a rarity!
Oh yeah, Mk2 handles are completely different too :)
Just checked etka -
Part no. are as follows -
Left - 867 867 179
Right - 867 867 180
if you add an A on to the end of each part no. that gives you the grab handles with the holes for the remotes.
Hope that helps!! :thumbsup:
