mk2 coupe fuel tank
need a new fuel tank for my late mk2 coupe wheres the best to get them does vag still do them if so are they dear,
many thanks
david
  • Views 798
Just to let u know. i got a good deal off ebay few years ago on one for one of my mrk2's but once i fitted it. It turns out
the fuel gauge sender from the original tank has a diffirence. Although it fits the replacement tank properly and stuff.
There are diffirences in the depth and shape of the economical replacement tanks to the originals which means the fuel gauge sender units from original tanks will give u a false petrol gauge reading. E.g when u fill up half a tank it will show up as quarter tank fuel. Or few gallons in n its barey off the white line.I cant give u any advice on what to look out for and what to get. What i can say is get a replacement fuel gauge sender aswell from the same person/company u get you are replacement tank from. The mrk2s are quite a straightforward job to change them aswell,If you are fuel pump has not been changed.Change it aswell.You will notice a considerable diffirence in performance because of the clealiness and pressure of you are fuel.I'm talking from experience.
many thanks
david
