MK5 Aerial Base
Hi, I was just wondering how you take off the MK5 aerial base. Does it just screw off? I don't really want to mess around with the wiring which is connected to or anything. Just want to respray it because its gone really dull and grey.
  • Views 850
If it's a beesting, it'll be the same as a Mk3 I guess. Drop the headlining, unbolt it from underneath and there should be a little slack in the wiring to pull it through a bit.
