Very nearly crashed
Pooped myself earlier, was taking my mate home, proper pissing it down with rain, coming down a main road at like 30-35, braked to turn right..
The front locked up, started sliding at 45 degrees down the road, thank god nothing was coming the other way, i tried to correct the steering but that just made the car spin the opposite way, went sideways and mounted the path.
Ended up on the path, about 3 inches from a brick wall!
I found it funny how other cars were stopping and flashing me to let me out, yeah, as if being parked sideways, half on the path and half on the road, with my hazards on, means I'm waiting to pull out lol.
  • Replies 24
  • Views 1.4k
Happens to us all at some point. Important thing is that no one was hurt and to look back, and work out why it happened and what you should do if it happens again.
I've done it before as well, like Yeti says I think everyone has at some point!
Its a common thing with Mk2's and 3's, when braking the back end goes extremely light, so if the front wheels lock you end up sliding forwards, try to correct it and the car will normally enter a spin.
Glad no-one was hurt! And by the sounds of it the car is ok too :)
Yeah I've done this before as well. LOL.
As said, at least everyone is okay. Hopefully your car is to!
Yep me and my main man are sound, and more importantly so is the car.
Just reminded me really to drive even safer in the rain, cause it could have been alot worse.
eeep, not good.
at least it werent at a fast speed although I've had 1st hand experiance of low speed impacts in a polo and there still not all that good.
i had it happen to me once on the a3 late at night luckily...not consentrating and forgot about the camera, slamed on the anchours and started to see my boot. let go of the brakes straight away though and it straightend its self up.
not happend to me yet :D
hopefully it doesnt either
its so easy to get the backs of mk3's swingin out! i find that my arse end like to swing out alot in the wet :lol:
it happens to the best of people just treat it as a lesson to be learned.
Next time if you lock up the front wheels get off the brakes and then apply any steering correction. You can't steer with locked wheels, they need to be rotating. Do this all gently and try to keep calm (difficult I know)...Mk3's are easy to lock up at lower speeds as the thin tyres are often low on friction thanks to the minimal weight pushing them into the ground.
Good job you/no one else is hurt. Learn for the experience as we all do.
IAM Action Man providing some handy hints :lol:
I learnt the scary way that you don't drive 'enthusiastically' in the wet. Roundabout on national speed limit dual carriage way, speed limit doesnt change so i managed to exit it around 50mph, and then wondered why my wheels weren't turning me round the corner... Pooped myself, but didnt touch the brakes and guided it round just managing to avoid the kerb. Won't be doing that again in a hurry!
hahaa chris..defo tryin 2 handbrake it round the corner haha..wonder if jish's plates still hanging on haha..
gav
Gav man lol.
I think they'll be fine, that velcro was quite strong.
haha all gd.. :-D
I learnt too! Was quite funny ending up parking on a flower bed right next to a petrol station though. Didnt help with only the front being lowered too!
Best bet is to back off!
I really really really disagree here :lol:
check the chassis leg is alright., i lost it at about 35-40 and mounted a grass verge about the same height as an average kerb stone but a bit more forgiving than one! and managed to pull my drivers chassis leg about 2" out. or bent both to the one side or something. never reaslly affected the cars handling, just used to rape tyres and i only ifinally found out when i took the rad mount off, went to put the bar back in and the holes didnt line up lol
The other day on the way back from college, i was coming through the ne way system in the middle of Stratford in the p1ssing rain. the road goes round to the right (at about 90 degrees - quite tight) so i slowed down (into second). but the b4stard still trys to go straight on, I tryed gently easing some power to pull the car round, but it just spun the inside wheel. so just held the wheel tight and let it slow down and grip again.....
all this at about 20mph (and yes i have good tyre depth!) was just Waricshire's crappy road surface and lack of proper drainage.
Glad you and you are mate are alright man,
Olly.
^^ Mines exactly the same though man, when we go up Cannock on sunday nights, and there's just islands around the Orbital etc.. every turn i get drama, cant keep up with any of my mates with these biscuit wheels on.
We both need bigger rims :badgrin: The pickup has 14"s and they are a lot wider as well, so i will see how much of a difference they make,
Cool cool, i'll probably whack some on in a month or 2, just some cheapies to make it a bit more forgiving, saying that, by the time i buy then it will be getting dryer..
Ha ha it's loads more fun in a Loon because we can get the back end sliding around the Orbital islands :lol:
Dan
^^ They are a laugh at night when the roads are emptier, i just hate it when some boy racer gets up my arse flashing his hazards, then overtakes me while I'm sliding helplessly around the island!
Dan, does your's handle noticeably better with those wheels on?
when i first got my GT on the steels it came with it had shit skinny tyres and the handling was GASH
got 13x7s on now with conti tyres and the difference was unreal. handles 10x better
I'm not to sure because i put the suspension and the wheels on at the same time but i don't think 165/55/13 on a 7J help the cornering abilaties :lol:
Dan
