mk3 rear screen seal
Hi all,
My rear screen seal is knackered. When I'm washing the car and rinsing around the bottom of it chunks of the seal come off (not with a pressure washer or anything - just normal hosepipe pressure) and there's proper droplets of water forming on the inside of the screen when I wash it. Now I've heard they're bonded in? What does that mean? I guess it's not something you can do yourself easily so would windscreen places just take it out and reseal it for a reasonable price? Any recommendations?
Thanks,
Ray
  • Views 1.2k
I think in simple terms it means the rear window is glued onto the bootlid. I know you could probably get it off but i'm not sure what to use to glue it back in place! If i was you, i'd get a professional to do it!
Yes, they're bonded (glued) to the metal frame of the boot lid. VW, and any glass specialist I’d imagine, remove them with 'cheesewire' which just cuts through the glue, but it looks like an involved job. It could be easier and cheaper to source a better second hand white boot lid?
Thanks - I was never intending to do it myself! Worth paying a pro for that I think.
It could well be cheaper to get another bootlid but it seems very much overkill, and it's a 1994 car so I won't get one any younger. I'll give autoglass and anywhere else I can find a call and see what they say.
Thanks!
I went round the edge of mine with clear silicone sealer. At the sides theres a gap between the glass & the metal. I used a small nozzle & filled that gap right up.
Is your rubber seal ok? Mine was leaking through there too!
Well I never got round to calling about getting it refitted and I'm glad I didn't - had the boot plynth off today and found out that the lock is loose because the seal is knackered, and water was getting into the area behind the numberplate through here. I've cut some rubber to the right shape to be a new seal so hopefully that'll put a stop to it getting soaking wet and even stop it misting up so much in the rain!
The rubber seal is fine and the bit that's deteriorating along the bottom of the glass is actually a bit of rubber that runs along the bottom only, not the bonding.
Thanks for the help
Ray
Oh if anyone has the same problem you can probably buy the actual seal from VW - part number is 191827594.
