Currie's 1473 GT Turbo
Model: 1991 VW Polo GT
Engine: 1W bottom end with forged pistons, 310cc injectors, ported inlet manifold, de-wedged tb, oil cooler, k03 turbo on rothe manifold and psd downpipe, longlife system, schrick 268/268, standard digifant, 330d intercooler, crankcase modded for oil return, knock sensor and engine mount, fully port/polished big valve head, windage tray, fully balanced. rebuilt atv box with grippa lsd.
Suspension: KW v1 coil overs all round.
Brakes: brembo cheap discs and raicam pads with braided hoses all round [not suitable for people with 500psi legs]
Wheels and Tyres: Mattig ssf 8j / 175,50,13
Exterior Styling: De-badged grill, tinted indicators, and repeaters, foreign late tint rear light, carbon bonnet, carbon wrapped fuel flap
Interior: custom lightweight door cards, sound deadening removed, omp cage, corrado seats, relocated rear washer bottle rear seats removed
ICE and Security: No stereo as yet, probably to be located in glovebox if fitted, no security, lives in a garage.
Comments: hopefully a subframe soonish and possibly 14" wheels and bigger brakes but will be happy when its running.
  • Replies 62
  • Views 15.5k
Beast!!! Nice spec there. 1W blocks are just different stroke right?
How far off 'till it runs currie??
What have you done to the chassis to strengthen it??
Reading the spec, i'd would suggest a 51mm throttle body would be a good idea mate.
Edited by LregG
Very nice spec. How much of a pain was the omp cage to fit?
Different crank, rods, bigger clearance for the bigger crank and rods, no provision for knock sensor, different head bolts
Beast. R5GTT racers beware :biggrin:
also has oil jets and it does have provision for knock sensor.. now
Giorgio - a pain, i wouldnt want to fit it to a car i wasnt prepared to have a blat with the welder on - that said i have a sunroof so all the legs had to be chopped down, fitted into a non sunroof i think it wouldnt be too bad.
Gregg - this current spec is only to get it run in, am planning on switching over to emerald so will be able to use a different TB all together and one with provision for throttle pot. also the turbo is a temporary idea.
i have seamed the front engine mount where they always go and triangulated down in the corner. should have a subframe before its running any serious power and am hoping that will hold things together.
Edited by currie
Car Is Awesome!!!
Mental cool. I'm takin pointers here, me and my mate decided in a few years when the R plates are down we're gona each build a trackday monster, so I'll be keepin my 1.0 Polo and doin sumthan similar enginewise!!
Hope you've got a nice noisy dump valve to let people know you're turbo'ed!!
Looking good dude, will be a serious beast when its done!
hell no! recirc all teh way111
not really into the dump valve stigma, can sound good but whenever i hear one i just assume its a speaker so I'm going stealth.
should be nice and quiet this one, bout the same as a noisey GT. :D
Don't lie, you love the dumpage.
no mr barrymore
Lol I would paint the wheel centres red along with a red GT badge on the grille and one on the bootlid for the sheer unusualness of it...
unfortunately the red has been peeled off the bumpers although it has been experimented with around the lips of the wheels but had a habit of peeling off.
planning on getting some new wheels when its complete and works.
update: got the fmic all sorted and a new lower support bar made up, also drilled and tapped out the feet for the front half of the cage, tidied up in the engine bay a bit and as soon as i get studs for the turbo will see about mockin up the exhaust.
stealth beast...
stealth
yes yes yes. exactly the point! trying to make it as stock looking as i can - whilst still looking looow and hard!
stealth
it's deffently working.. :thumbsup:
Very nice 8-)
stealth
I love the idea of a stealth car lol, maybe fitted with infra red cameras and large screens for night driving without headlights. Note this is a very un-responsible idea and i withdraw it immediantly... :badgrin:
nutcase but i like it!
quick question.. what does the 1w bottem end come from ?
Seat Terra van. This car is the ultimate sleeper Currie i love it :thumbsup:
Dan
were you driving out of gosport yesterday at like half twelve ish? i know its well out of your way but i know you know liz... if it wasnt you it was someone whos car was very similar to yours...
were did you source your carbon bonnet from dood?
loving the hole theme u got going on..
