Trouble when fitting VR6 Golf seats in a 6n
Hi,
I've just attempted to fit my rear Golf VR6 seats in my 6n I have swapped over the metal backings from my original Polo seats and have cut off the fixing tabs on the lower seat pads.
The back rests went in nicely and a very snug fit - thanks to the guide in the FAQ section.
My trouble is I took the tabs off the lower seat pads and tried to fit and noticed the fixing bar was flattened off and wouldn't go through the hole...so I cut it back a little with a hack saw until the bar was round again.
Now when I go to fit the bars seem a little short and keep on coming off, another problem is the seat pads doesn't seem to fit under the back rests.
Any advice?
I was going to swap the lower frames over completely and took them off I noticed the Polo originals are more square whereas the Golf originals are more curved. I tried to swap them over but the leather seems a little strained/stressed by the more squarer frame.
Mahbs
Edited by Polo M
  • Replies 9
  • Views 1.8k
Monday bump ^^^
would it be possible to extend the leather under the seat with a leather patch maybe?
Hey Ash,
Could do but there must be an easier solution there must be quite a few people with Golf leathers in their 6n. :nod:
Just probably me being a numpty not being able to work out how to do it :retard: give me some electronics to work on any day :-p
Mahbs
Hey Ash,
Mahbs
:lol: was thinking you'd branched out somewhat from the lec'y world lol you got any pic's of the offending problem?
I'm going to give it another go tomorrow if the rain lets up. If not I'll get some pics of the bits at home.
So annoying the fronts went in a treat as well as the backrests in the rear just need to take a trip to the main stealers for a couple of slider clips for the front.
Next step is to wire up the heated seats which I would look forward too LOL.
You can run the loom straight from the battery for that though I think? I've still not done my dials whoops lol
Alrite m8 I've got mk3 golf seats in mine, on the backs ull find that the bases will actuallt sit a little further back than the polo 1's so 2bh u have to give them a bit of brute force and pop the bases in and they'll slot under the backrests nicely to give a good tight fit but u will be able to see the mounting holes slightly but theres nowt u can do bowt that. As regards to the frames actuali going into the holes ull find that 3 of em do and 1 will actuali just stick in a few mm, it doesnt affect the stability of the seat as its wedged under the backrests so firmly so i wouldnt worry but if u r then just weld a little piece on to extend it thro rthe hole altho beware coz it'll make thema idiot to get back out !
Seen as you are a sparky, is the wiring for the heated seats hard as I've noticed there heated but i haven't got the loom to wire them in, is this a particularly hard job ? I'm pretty good at doing things ma'sen so dya reckon its a DIY job and also what switches would you use to control them that would fit an look ok in a 6N plz ?
Tom
Tom
Cheers Tom,
I'll have another attempt to get the bases in tomorrow if the rain stops :roll:
I'm not a sparky but enjoy that sort of work. I've got the original Golf Mk3 loom and switch but I'll get you some more info during the week as I should be getting some wiring info and a switch for the 6n. You need to have the relays in place under the seat, I thought I'd mention it as they are often missing.
Mahbs
That'd be gr8 if you could thanx m8 as they've been in a couple of monthes now and want to enjoy the rest of the winter with a warm butt. Also let us knw hw you get on with the actual job, good luck. :thumbsup:
Hope you get the weather as its the same up ere atm but its a worthwhile mod as standard polo seats are shit and uncomfortable !
