Removing Heater Dials
I've got it loose, but the rods that control the dials movement i cant remove, it says to unclip them but i cant see anything of the sort.
can anyone help, mike.
bump anyone this is quite urgent
i did it once but cant remember lol but be careful when taking it off as the plastic rings that go behind the left and right dials break easy, found out the hard way :lol:
Theres 3 metal clips (one on for temp, 2 for direction) this can be prised of with a flat head screwdriver. theses ar located on teh bottom back of the plastice matrix. I found bes way to get to these is to remove the electric windows panel as well. then pull the whole matrix ( once undoing it) out and angel towards the passanger side. makes its easier to get clips off. once off teh rod nee to be leved off the controls witht a screwdriver again.
HOpe this helps
cheers mate ill try this later :D
got to ask but why do you need to know ?
I'm wondering cos I'm bored of the colours and general look of mine and was wondering if you were changing them cos of that, or just because they are broken :lol:
yeah I'm changing the colour to red, but i need to get a red filter from a mk2 ibiza too, only just clicked on that will need changing aswel :( :lol:
trip to the scrappers :)
