Shoud i debadge...
I've been thinking of removing my bumpstrips and badges but I'm not 100% sure whether to.
Your opinions would be good.
p.s. could anyone do a photoshop?
  • Views 990
I'm not sure how you can do a good chop with that pic so if you have another from the rear side with the strips and badges I'm sure that will help someone and if you remove the badges on the back you will have to get the holes they are fitted in welded up the side strips will be fairly easy though, personally i would do it but its not my choice its yours.
bumpstrips look good man, did it on mine. tassssttty. BUT the rear badges have holes. so they need to be filled. and when you remove the bumpstrips dont remove the one on the rear arch. there is a hole there too. i found that out the hard way... :S
and debadged grilles look good. but i quite like the audi grilles, would look awesome with your colour of car.
cheers bud
ste
i was thinking about removing the badges from the rear but leaving the actuall vw badge and just removing the words,
on a 'mk2 square' if that makes any sense
Edited by ozzy
