points for wheels sticking out?
put my spacers on and my wheels poke out a little can i get points or will it be a fine anyone been pulled over for it? cheers
  • Replies 8
  • Views 1.9k
Grey area.
As long as the tyre tread is covered by the top of the arches you should be OK.
as toby said, it is a grey area.
I've recently learned that its not an MOT fail. a tester can only put it down as advisory :?
it depends how much they stick out, and hoe friendly the police are around your area!
This is how i ran my jetta for about 200 miles. tbh, these do stick out a tad far... the tread isn't covered by the arch, but i had no trouble from the po-po in that time
Edited by Joel
I want that car! I love the front end!
Mine stick out a inch max do u think I'll get any points?
If it's your thread on the tyre you could do but if it's only the wheel and no thread you should be ok!
You can't get points for it, a fine at the most, but if it passes an MOT then i guess you're ok..
Fcuk me i would shagg that loon! :wub:
Yep if the tyre tread is fissible when looking down on to the wheel the the fuzz with either give you a producer or points, although its not a mot failure!
:drool:
