door lock not working
My door lock on my drivers door will not open with the key, if i use the passenger door then all the central locking works ok on the drivers door, but when i use the drivers lock it feels like the lock is turning but nothing moves. is this a common problem and how do i fix it
  • Replies 11
  • Views 2k
Is it loose and just spin?!
when i turn the key it turns both ways like it should but it feels free, where as the passenger door when i turn the key i can feel it pushing something, i can lock and unlock the door from the inside its just that the key won't operate the lock.
Hi.
I have just joined your club because my girlfriend has bought a 1999 Polo with the large textile sunroof. two door version.
She has confronted me with the challenge to repair the very same problem as discussed right here. She cannot open the drivers door from the keyhole. Lifting the stick from within the car does the trick, and it can be locked from outside. (but not reopened)
I would like to score by fixing this, so if somebody can guide me to remove the doorpanel on the inside - please. I dont seem to find any cover
covered holes or screws anywhere. Is it a snap on ? or ??
Regards
Ingemann - There are two screws behind the handle, that should just prize off using a flat head screwdriver. After the screws are undon the panel just pop off (its on lil poppers behind the panel)
Dont force it too much and remember to take the door pin out by unscrewing it by hand.
P010 - In regards to your problem I'm not sure if this is the same problem I had but mine was. . . The barrell you put the key in was snapped from the inside so just kept spinning. I swapped the door lock from passenger to driver side and then just put a de-locked handle on the passenger.
Hope this can be of some help.
Nick
Thanks - Ill try this as soon as i can get hold of that fast Polo of hers.
I will let you know of the solution either way - and the reward. 8-)
Good weekend to all
Ingemann DK
got the same problem with my passerger door now but my central locking is not working, my lock is just loose and spinning?? havnt got a clue how 2 fix it???
Hi again.
Finally, she took time to spend some time with me. -and of course I had to use it on her little motor..
I took everything apart, and found two things:
The elongated connection between the doorhandle and the opening mechanism.(a screwdriver-like stick of 10 cm) were broken at the handle side. this must have been caused by another discovery:
The retrofitting of a central locking system.
By fastening the solenoide sticks elongation (app 30 cms long wire ) to the door pins wire. the whole mechanism became so heavy to operate, that the conecting rod, had to do a heavier job opening the do by raising now both the door-pin and hauling the solenoide piston out. This caused heavy wear to the cast-iron connection , thus making it break into pieces, and destroying the lock with tiny metalwaste.
I am lookig for a complete doorhandle now. With a new key - so she will have to get used to two keys from now on. I am not wasting anything on new coding for two doors and the ignition.
Very easy to take the locking and the handle apart-
Just 4 torx-screws easy loosened by allen key too.
Remeber to trim for an easy going lock, iif you have tha same problem.
Thanks for a good help.
Ingemann
cut a tennis ball in half put it over the lock and smack it hard
take ure handle apart by taking the screw off the end of it on the inside of ure door
then replace all tha parts from behind it
ue local stealer will know exactly what u will need its not hard hehe
I took the detached handle to the garage.
The dealer was able to replace all the broken parts one by one in the detached handle.
They must have come across this many times before - price: 12 pounds and a 10 pounds for the coffee-box for helping me.
Very fair I think, instead of 400 for a new setup.
over and out
Ingemann DK
its a coomon problem on the vw range the spade part on the lock is made of cheap metal need a new kit asecible from vw bit of a fiddley job with smaal parts am a pro at this done loads of the bstards lol
