Help, cant get front wing off mk3
I've undone all the bolts underneath an ontop, the arch liner has been removed, the screw at the front. the end closest to the door wont budge and its chipin my paintwork!
need some advise please :D
sure is cold out there, my fingertips feel like there burning !
There are bolts behind the sealer at the door end.
3 to be precise! They can be a bit of a bastard to locate cause they are usually covered in sealer.
hey i still cant work out where they are? do you mean after that ridge at the bottom of the car?
itside the wing near the door edging there are 3 10mm bolts under the think sealer
took me ages to find.
in behind the arch liner if you where to stick your finger where the side repeater would be and to the right theres 3 bolts, and once you have them out the wing is also stuck on usually with the sealer and is a real bugger to remove without bending, good luck
