My Polo is ill!
Hi guys,
i've discovered today that my fuel tank is leaking, and it's lost a fair bit of fuel so far since i've been at work.
It's a 1988 Polo (C i think) 3 door with a 1050cc engine... i've just been quoted £300 to repair it but don't really think it's worth me spending that much on a 20 year old car...
The guy i've spoken to was recommended by Volkspares, which is just down the road from me, he has also said that if I provide the tank, he will fit it for £180.. still think i'm gonna end up spending at least £250 on it even that way! :(
Anyone in my area know of any places I might be able to get it doen cheaper? Else it may be down to the scrappy, and that would be a real shame for a car that's only done just under 70,000 miles!
Rob :cry:
  • Replies 17
  • Views 1.3k
Tanks going on a mk2/3 are a common problem.
You could get a tank from a yard, but it will take a while to pull it off and theres every chance in the world it could be just as wrecked as your own.
Only real solution is putting a new tank on it (and putting a lot of rust proofing on the tank itself before it goes on!).
Where abouts are you located? Theres probably a member local to you willing to help out.
Hi,
thanks (or should that be 'tanks'?!) for the speedy reply,
I'm in Bexleyheath, which is South London / North Kent border!
Rob
PS In the meantime, has anyone got any suggestions for draining what's still in the tank? It's leaking a fair bit, and I don't want to cause an explosion!
Edited by r_keates
Those prices are INSANE!!! Tanks cost about £50 and should take any competant mechanic with ramps etc... no more than 2 hours work. I can do it in 3 or less crawling about on my back with the car on axle stands. Where abouts in the country are you?
EDIT - ahh too far from me but maybe you'll find someone local who will do it for a hell of a lot less than £300!!!
I've had a couple of mk3s with this problem and normally as long as you don't fill them up with more than a tenner they are okay. Its just once you start going over that amount then they start to leak. Although with the current price of petrol you can probably get more than a tenner in. LOL.
Tanks are available from around £60 IIRC.
I'm sure someone around that area who is into there mk2/3s can do it for less than £180! First time I had mine done, someone off here offered to do it for £60! That was before I bothered to do things myself!
Don't forget, they might seem like mad prices, but i'm prob paying at least £60 per hour round here for any kind of mechanical work... the joys of being in the south!
had my tank replaced about 2 years ago cost of tank was £60. think i paid about the same for labour,would have done it myself but the car was in edinburgh and i was in the midlands.
Whereabouts u based mate?
i did a tank swap before. i took the old one off, took the one off the donor car, and refitted it to mine. all within 4hours of scrabbling about on my back on a muddy/stony floor with a 2ftx2ft bit of ply to lie on. problem there is I'm 6'4 lol! and it was THE hottest day of 2006- the thermometer outside our house was reading 34 centigrade that day
Just found this is it helps..
ebay: 300191000236
ebay: 300191000236
Thanks for the replies, but mine would be a mark 2 wouldnt it, at 1988?
I may look into changing the tank, i've replaced most of the braking system on a Sierra before, as well as doing various bits to mates' cars... I know my way round a spanner lol.
For anyone who has one, is the procedure for replacing the tank shown in the Haynes manual? I haven't bought one yet, as I wasn't sure on the car's future, but if it's in there I guess I may as well buy one so I can decide if I want to take on the challenge... the only reason i've not dived in is that it involves a flammable material... give me wires or hydraulics, no problem... but flammable petrol?!
Rob :)
Its probily a safe bet that a mk2f (often called a mk3) and a mk2 will have the same tank I'm sure someone will conferm, is there no-one your way whos breaking a mk2/3?
I know if your converting a mk2 to a GT you need to use a GT tank. I can't remember why or if its just when your converting to GT but I know there is something in there.
might be something to think about before you end up buying the wrong part!
Cheers guys, i've got someone having a look at it on saturday; they're going to confirm where it's coming from, then quote me on repairing it. It's a guy who's been recommended by a friend, and seems to be a very genuine person!
Hopefully he'll give me a better price than what i've had so far!
Rob
where do the tanks leak? i Have a mk2 and would like to prevent it :-)
if you know your way around a set of spanners then you should be ok doing the job yourself, it's not hard. just get hold of a haynes manual for instructions and pictures etc..
sparky - they rust through generally where the filler neck is welded to the main tank body. You could clean the area up with a wire brush and some of that rust convertor stuff (krust or whatever) and then paint over it with some decent anti-rust paint (POR15 from Frost.co.uk is good), paint as ,much of the filler neck as you can get to.
Last summer I took my leaky tank out.
Filled it with water and marked penned where it oozed through the rusty patches.
Slapped a load of araldite all over it.
Slapped a load of hammerite all over that.
Stuck it back in.
Perfect since then - total cost £6!
For prevention - all mud and shit collects around the filler neck - clean it all out!
Lol, looks like a good "quick fix" Fonz... Not sure how i'm going to play it yet, the guy hasn't had a chance to look at it for me yet, but he is doing it as a favour so I can't complain lol.
Hopefully this week i'll be able to get it sorted one way or another, my friend who's living out in Cyprus until July has offered me the use of his 2004 1.6 16v Clio, so if I decide not to sort the polo at least i'll still have transport!
If it's not going to get fixed i'll probably offer it up on here to a good home!
Rob
