Removing the VW tailgate badge - Mk3
As above, I've got the grille and badge off, and the primer's drying on that, but how does the rear one come off?
  • Replies 11
  • Views 1.8k
Just pulls off mate, dont yank it thou
It looks like there's a rubber ring behind it, does it kinda sqeeze into the hole?
the vw is plastic and its connected to the rubber thing, just put something like a credit card etc behind it and it should slowly come away with a bit of pressure.
thats all i did, i haven't even got a rear badge coz i smoothed it.
good luck
Edit: not sure if this would be the same for a mk3 though?
Edited by MK4_amy
So there's no glue or anything? cause it's got to go back in when its painted.
its like a gluey sticky back thingy
Theres no glue involved, not sure if there is on a mk4 but definately not on mk3. The badge and the backing are 2 separate bits, like Amy says just get a credit card or something behind the backing and prise away.. the backing will come off once you have the badge off
Sweet, cheers guys, i'll do that one tomorrow once I've got the front one dry and back on.
I just pulled mine off, its got a vinyl backing and the badge has 2 small pins which clip into 2 holes in the boot.
If you dont want to risk damaging your paint push it out from inside the boot, take the plastic cover off the back and pop it off!
I've taken loads off and IU can honestly say I've never damaged the paint or boodlid once.
I normally just press on the bottom and just kind of prise the top of it outward and it usually pops off.
Sound, it will be done, the front's still drying, will give it another coat of spray before i go to bed lol.
Also, when i removed the grille i took off that seperate piece that kinda blocks some air going into the engine bay.
Sprayed black that ducting that goes from the intake to the exhaust heat shield, now it goes from the intake to that new opening behind the grille. Should be a bit better as not that much air was getting to the filter before.
