smoothing 16v bumper
hey all.
i have just got my 16v bumper off europarts and i want to smooth off the side vents before putting it on.
how do i go about the smoothing? what do i need for plastic welding? and more to the point, how? lol
help will be much apreciated.
cheers
Edited by Hardin
  • Replies 13
  • Views 1.7k
anyone please....
A professional!
well...you could plastic weld yourself but I'm really not sure how you would go about doing it with the replica bumper from euro parts as i assume it wont be of the same type of material the genuine on is of -polypropylene (i think its this.(
if however it is polypropylene then you can use your 8v bumper cut peices from this to fill the grills on the 16v bumper go hire a plastic welder which is about £30 a day then get some polypropylene rods few quid each and begin welding the grills on the 16v bumper using cutouts from your 8v bumper, then a touch of filler on top, sand down and bingo- job done. ready for spray
you might wanna get a bit of practise with the welder first before you start welding you valver bumper.
hope this helps
I'm not a pro, just an ordinarry DIYer :-p
Did mine (even painted with rattle cans 8-) )....
What i did was..
Put paper up against the gaps where the grill is/was and drew the shape to make a template, then cut it out (repeat on everything you want smoothing)
Then using my 8v bumper, at roughly the same angle (to get the bend close) i marked out the template shapes, then cut out about 2mm bigger
I also cut thin strips of plastic from the same bumper
Then using a hot soldering iron i went around the edges of the cut out untill they were melted a little bit, then pushed it into the gap what i was smoothing so there was about a 3mm deep ditch. Then turned the bumper over a little and pressed blobs of plastic filler to the bumper and the cut out to hold it in place
Back on the front side, using the hot soldering iron and a strip of plastic i started to melt the end, once its ready to drip - sort of smooth over the gap between the cut out and bumper with it. Let that dry and repeat untill youve built up enough to hold it in place (doesnt matter how rough it looks)
Once the fronts done, turn the bumper over and do the same to the rear, try not to go over the blobs of filler
If you think that youve done a good job, then flat back any areas that stick out further than the flow/shape of bend of the bumper. And also flat the bumper area around where youve just welded the cut out down about a mm
You should now have a bumper that looks a right mess :lol: dont worry
Using plastic filler, spread a good helping over the ditch left from when you put the cut out in, flat the down
Then give the whole thing a skin of normal filler, flat back untill youve got the flow/shape of bend etc etc as good as you want
Sand the whole bumper, primer - paint, flat - laquer :thumbsup:
Hope that helps 8-)
Edited by walshc
how many rattle cans did you need to use ?
Of paint? 2 big ones (cant remember how much is in them :oops: )
have u got a link to europarts to direct me to the 16v bumpers
cheers mate
when the bumpers come are they just in primer
yer mate, they dont have any grills tho or the plastic splitter
its £50 for the grills aint it?
then about 30 for the splitter
so the sports version bumper is £31.80 on the website. add on the prices for grills and splitter
total £110.80. wouldnt it be better to buy a genuine second hand one for around 60-80 quid with grills and splitter or am i wrong :?
Edited by dhali
It would be better yes, and it would fit perfect too
I've heard the ECP ones dont fit right??????? :?
