Mk3 Battery Tray Repair Section
Just wondering if anyone knows of any repair panels available for battery tray/rear bracket? Need one for a project!
Pettsy
  • Views 1.6k
its probably as hard to swap the whole thing as it is to patch up the hole.
the one on my mk2 had rotted to the point of getting your hand through the hole, i just drilled out the spot welds in the clamp and chopped out the rot, folded up my own plate and got it spot welded on there, real pain in the ass trying not to catch the trim alight when welding. alternatively chop a panel out of a better condition car from the scrappy.
i've removed all of the dashboard etc so trim getting in the way isn't a problem.i did try welding a plate in but wasn't happy with how it looked so wonderd if a propper repair plate was available
by some sheet steel and make it.
then you can cut out whats needed to be and have a piece you have tailored, rather then bodging plates over holes.
i looked at a bad one on a friends and though that a simple "L" plate about 8-12" long and 3" deep welded in from the underneath (Inside) would do the job aslong as the old shit metal was then removed using an angle grinder afterwards.
Seam sealer that and paint it - bobs your uncle.
KiZ
yeah, thats probably what i'll end up doing tbh
just done mine the other night! had much fun removing the fibreglass repair I did as a temp fix! once that was done me and my good friend denver set to work on chopping out the rot, there was pleanty of it!
heres how it looked before the grinder attacked (cue shonky phone pic!)
big hole (it got a bit bigger too but I didnt get a pic of it)
once the rot was cleaned up, my main main denver set to work with the welder (not pretty but space was limited and I was reluctant to remove the dash even though it would have made fixing it easier. I was left to watch for flames, of which there were pleanty! think I would have prefered to have been doing the welding as the polo footwell isnt the most comfortable place to be!
with it all welded up, I was left with the easy, if messy job of undersealing the tray, the top was ok, but it was a bit of a game to do the underside, could have done with being one of those circus types that squeeze into small boxes!
finally I had to make a new drainage hole as it had previously been welded up by some numpty (i;m fairly sure this was the cause of the tray rotting out for a second time), this was easilly sorted with a big drill bit and a die grinder to enlarge the hole. another job of the list and my hand are now cut to shreds!
