viewing a mk3.........
Going to be viewing a mk3 polo sometime soon and i wondered if there is anything in particular to look out for or to check. Besides the obvious.......
Don't want to be buying a shitter.......
Any help or advice would be greatly appreciated!!
  • Replies 10
  • Views 1.2k
Battery tray
Sills
Gaps between trim/spats + Paintwork .. Water seeping underneath
Oil in the Coolent bottle / top of head creamy
Excessive play in front wheels .. ie bushes .
Thats about all i can think of mate .
They rust and leak around the fuel filler neck. Pain in the neck to replace the tank!
Apparently the head gaskets usually go about 80,000 miles.
Check for rust in the spare wheel well.....
All the above and exhausts, they have a tendency to snap off. Its usually just the rubbers but if your clever you can convince someone who doesn't know much about cars that it needs a whole exhaust system when it needs about a tenner spent on it, lol.
Cheers for the replies. It is a GT i will be viewing but it is quite far away and don't want to go and view a poo box. Basically just rust and the usual head gasket, cambelt and service jazz.
Just wondered about the particular places where rust often occurs on these cars. Sounds like most have been mentioned though.
With GTs its normally under the arch and sill trims. Realistically you need to have them off to check, but they are riveted on and I'm sure most people would be slightly pissed if you came to view it and then started drilling the arches out!
Also if it has a sunroof pour plenty of water on it to make sure it doesn't leak!
Looking at the current weather i think it will be easy to tell if the sunroof leaks or not :-) Obviously i won't be able to get the sill trims off...... i love a good gamble.
Will give it all a good look over though. If the rest of the car is a bit dog rough i will expect the parts i can't see will be :-)
I'd advise the following to avoid having to diagnose irritating problems later:
- Get the car running before you look around to make sure the radiator fan comes on.
- Blip the throttle before test driving - revs should rise and not drop. Hopefully it will idle steady at around 850rpm when warm. Test drive it in every gear.
- Hold the revs steady at 1,500, 2,000 and 2,500 to check for misfires.
- Usual oil level and leak checks, don't be put off by the leaks around the rocker gasket as I'm sure you're aware.
- Try and get the car on full lock around a mini roundabout or something, check for any unusual knocking sounds.
- Turn every electrical item on and make sure they work!
- Check the seats move and the driver seat height can be adjusted properly.
- Another potential rusty area is the spare wheel well, it is undersealed but I've seen a couple of rusted ones complete with holes.
Check the history before you buy, look for replacement parts other than usual service items and see if the owner can enlighten you as to how the previous item failed. Look for a recent service and cambelt change.
And make sure you're getting what you want i.e. a genuine GT as opposed to a conversion. I'd pay less for a conversion unless it was inseperable and top notch work.
Awesome response....... i will think of this while looking. It is a genuine GT, not a conversion.
I'll come along with you mate if you want, as long as its not tmrw afternoon before 4pm. I think I've managed to find just about everything that can go wrong with a mk3, in just one car!
from a mk3 guide i made a couple of years ago...
1. Water/petrol can collect under the arch trims and underseal and leave you with rust problems. Keep a good eye out for this.
2. Also check the runners above the rear lights as dirt can collect, block the runners and cause rust too. These problems seem to be less severe with metallic cars.
3. Check where the petrol filler neck connects to the tank as they rust through.
4. Check the back of the battery for rust
5. Check round the window rubbers for signs of a respray
6. check in the boot for the boot sticker and to see if the boot floor has any bends/ripples in it (signs of accident damage).
7. Check the front wings for the VW logo and clips each side
8.Check the bonnet for the rubber buffers when it's closed
9. Head gasket blows around 80k.
10. The mounting plate holding the fuel pump, in-line fuel filter etc at the back of the car suffers badly from rust. Be sure to replace this as soon as. By either making your own or ordering a new part.
11. If the Polo hesitates for no apparent reason, when accelarating or just travelling along at a constant speed (like you've tapped the brakes on and off) this could be a sign that it needs a new throttle body potention meter. Around £40-£60.
12. If there is scratched paintwork on the door sills, it's a sign the door has dropped and needs adjusted.
