Po-looow!
Right the polo mk3 Gt is soon to be low...going 90mm Front 80mm Rear...its going to be my day to day car
running 13X7 wheels my estate in mk is as follow...top of the road turn right speed bump...turn left speed bump
so at the moment me thinking i might not be able to get out my road :|
anyone got any pics of a polo this low just wanna see if it a mistake going this low...
cheers
  • Replies 9
  • Views 1.6k
90/80 is insane dude, 80 all round is mad low, just look at redsquares on here.
your guna struggle everywhere and if its a mk3, alterations to steering and brake master cylinder i think.
Mark drove his around at 100mm all around on 195 75 13's, parked side by side it was lower than Dan Krebs Mk2F. George (rolo) cut his springs to just one coil, Lee-Roy also ran his lower than an 80mm drop.
Speed bumps were a problem but they were do-able.
60/40 ftw...avoid having an un-useable car. You'll have to worry about speed bumps, steering arms/drive shafts being at the wrong angles and all the problems this brings.
yeah I'm 60/40 on a mk3 gen (looks good but i do have 14s on it) but is still usable just hates potholes :-(
Hmmm Prob should thought about this...meh o well...
*looks for new place to live* how much is it to do the
alterations..? trying to go lower than my mates
caddy, dam my competitiveness...was gonna see if there
was anyway i could go lower... :-D but think might stop
at 90/80...will i need new part?
Maybe look at getting the steering arm mounts on the struts lowered to prevent the steering arms rubbing on the brake servo.
here a thread tht might interest you!
its one i started a while back!
i know i have a mk4 but the totak ground clearance i hve under my car is a whoppin great 55mm
i drive everyday like it, i dont find it that much of an issue and i hve speed bumps all around where i live
http://www.clubpolo.co.uk/forum/index.php?...c=90564&hl=
Well I've got 45 mm of clearance from the subframe to the ground on my mk3 and it was fine as long as you don't drive like a tw*t ! :-p
It's dropped by around 90/100 mm on 175/50 13"s .
Speed bumps are okay , if a little noisy and passengers in the rear are a definate nono :thumbsdown:
Just do it !
anypics?? which car is that??
