Aerial Fitting
Hi there!
I have just purchased a 1988 F-Plate Mk 2 for my wife for the princely sum of £300. It was previously owned by an old lady and only has 40,000 miles on the clock with full service history. Not bad for a 20 year old car!
However, it is in such original condition that it has never even had a stereo fitted - something which my wife considers a must. Fitting the Stereo itself is no problem, but first I need to fin an aerial. There is a pre drilled hole for an aerial on the FNS wing which currently has a small plastic blanking bung in it. I just can't for the life of me work out how to get the nut onto the back of the aerial. Surely to goodness I don't need to take the whole wing off?
Any tips would be most welcome!
  • Views 834
remove the plastic liner inside the wheel arch. that gives you access to inside the wing. I think that most aerials need the nut screwed on from the outside.
or buy her an ipod.
(and you need a thinner-than-standard aerial (from GSF))
Edited by Fonz
All done, fitted and working! Thansk for the tips!
