The GT - ITBs and cage? :)
looking good dude, I'm looking forward to seeing this running on the itb's.. what setup are you going to be running regarding ecu/management for them ?
  • Replies 42
  • Views 5.1k
Got a megasquirt ECU that'll take care of it all, just need to get an Innovate LC-1 wideband setup and finish my inlet manifold and then it cal all start getting put on, might take a while yet though :lol: Hoping to start mapping in the mext few months.
nice work, thats a tight fit with the cage
yeah, might be able to adjust it a bit for the door pods but the seats would need the subframes modifying.
Where did you get the cage from? I can see its an OMP item. Can you PM me price etc?
Cheers, Steve
Cheers, Steve
PM'd you
thats gay
thats gay
You're gay :lol: Get your polo back on the road!
wouldnt mind knowing were you got the cage, and whats the advantages of the mega squirt?
and love the wheelssss want allycats? lol
I got it from a member on here after he had an accident in his rally car (slight frontend knock so cage was ok)
I believe the (cheapest I could find) they are £477.31 brand new from here for a full cage:
http://www.balancemotorsport.co.uk/product...ecnumber=101364
Half cages are £239.99 at:
http://www.southwestmotorsport.com/rollcages.htm
But I haven't researched them that much.
I love my wheels too :lol:
Megasquirt ECU allows you to map your car properly and get the best power possible, this'll allow me to properly fuel the engines with my throttle bodies.
Edited by Jimsiss
hurry up you penis =D
Whilst you can get the original VW Digifant engine management system remapped, it relies on a signal from the airflow meter as well as the throttle position sensor to detect how much load the engine's under. When you switch to running ITBs you would need to run a plenum chamber to retain the air flow meter - but the air pulses in the inlet tract really upset the flap on the air flow meter, making it give squiffy readings. This makes it very hard to get the car running nicely at idle or low loads.
With Megasquirt you've got a lot more flexibility as to how you set it all up, so you can avoid this problem. The alternative would be to switch to a hotwire airflow meter and use Digifant.
  • 8 months later...
This ever get finished?
  • 3 months later...
Finally got the bits back so I can finish my manifold, unfortunately I'm away to China for a week tomorrow morning so no progress will be made. Here are the bits:
Nice flange ;)
How you gonna weld your manifold? TIG?
Yep, just need to clear the shed to get at my TIG set now :lol:
Awesome project! Really wanting to see how this goes on!
AHAAAA! (she cried). Being an engineering numpty I couldn't for the life of me figure out how to make the manifold that is going to hold my carbs on because the ports are oval and the carbs are round. Now I know, thank you so so much! :-D
I'll be mostly cutting up toilet rolls this evening to figure out how I'm going to do it in metal!
