sqeaky doorcards
I find when I wack up the sounds certain songs make my doorcards sqeak at high volume. Anyone else find this? drives me mad, anyone know best way to solve this? any help would be great as it's pissing me off now :lol:
MK4 polo btw :-p
  • Views 1.2k
MK4 polo btw :-p
Ash, take your door cards off an check that your trim clips are all in place and in a useable condition alot of mine were either missing or slightly damaged. They are about 80p each from VW. Also the foam insulation has two functions a moisture barrier and as a sound absorber so get that sorted asap.
Also the door cards are resonating at the frequency of the sound being output by the speakers so ou may have just found the natural frequency of the door cards :lol:. Try slightly adjusting your equaliser to see if it subsides or excerbates the squeaking.
Mahbs
MK4 polo btw :-p
Mahbs
I know a couple of the clips are damaged, shall get that sorted. Foam is attached correctly, what about dynomatting the doorcards? would that help at all?
Through further investigations. it seems to be the window mech that vibrates! Anyone else get this?
I get this problem but it doesnt help that most of my clips are broken, the door linner is tapped to high hell and I have some fairly beefy focal comps lol. Most of the time I dont notice it though
Today, I cut away the foam and dynomatted the whole lot :lol: Then I tighten'd all the little screws on the door card at the back and that seems to have nailed the sqeaking from the cards. Sound is now whisper silent :D
