Paintwork disaster
To cut a long story short, I've destroyed the paint work on the driver's side front door of my Polo with 1500 grit wet and dry paper.
I used it wet on the door in a circular motion, and as a result there are fine scratches all over the paintwork. From a distance it looks "dirty", if you see what I mean.
Aside from paying £200 to have it resprayed, what can I do to make it look better?
If it has to be resprayed, can anyone recommend an inexpensive bodyshop in the Birmingham area?
  • Replies 19
  • Views 1.8k
Why did you use wet and dry paper on your door?! :shock:
Sponges give such a better result!
Have you tried using a buffer n T-cut!
Thats one way of getting dirt off :roll:
I know, I know. Was doing my first and last attempt at DIY spraying. Read some instructions wrong and "prepped" the wrong bit of door.
You think T Cut will work on this scale??
use some G3
use some G3
is that the cutting compound stuff?
try using some light cutting compound (most of the scratch removers will do fine) and using a powered buffer (also known as a mop) to cut the laquer back gently until the scratches fade then use a good polish to bring back the shine and finaly wax to protect.
yeah buff with G3 as long as you'v not gone through the clear coat or paint it'll be fine
Iff your prepared to travel to Nottingham i can direct you to a garage that would prep and spray the panel for around £50
Wheres that then pal?
it would depend on the colour of the car ;)
if it's silver not a chance i would be getting a single manal repainted it needs to be blended into the other surrounding panals ;)
www.uniquebodyandpaint.co.uk
paintwork yorkshire way this guy is awesome ;)
Maybe... what are the details?
Go over it with some 2000 wet and dry to flat it out and then compound / glaze / polish. It may need machine buffing out though.
Right il have to get a map and draw on the location for you I'm not too sure of the garages name but have seen alot of there work and have had quatations myself .
Iff i find the location on the map and the street name I'm sure i will be able to find the company name and contact details .
There rather cheap and spray to a superb quality ..
Nice one
Alternatively get a Skoda then use any grade of paper U like and still get a good nights sleep!!!
the bit thats sanded down might go back to colour when you laquer it ? well thats my experiance from sanding with fine paper and then laquered. but you should be able to polish it out with somethings like the t-cut range or 'mers'.
Otherwise cant you just get a can from halfords ? :p
t-cut an elbow grease or use it with a buffer.
is it flat or metalic?
should come up fine agin as long as it not metalic an you've gone through the laquer.
Did you find out the garage name?
haha, i don this on my white mk4, so i just decided to rub it all down and paint it matt black with a roller, didnt like that so i rubbed it all down again and spray painted it gloss black with rattle cans, lol.
poor car.
good luck though.
