wet seat belt in a mk3!!
hey guys any clues? my guess is can only be the rear window...just worried where it might be holding water and damaging the body!!!!!!! that an am fed up of forgetting to leave ma belt plugged in over night n puttin a wet belt accross ma chest at 630 in the morn lol!
  • Views 1.3k
mines wet too in the GT... I've not had time to investigate yet, but its been pissing it down here, its not surprising really...
is it a sunroof model? if so check the drain holes! if not check the window rubbers on the rear quaters as these sometime let water in. also pull off the rear quater panel trims and check for damage, as rot can occur near where the petrol filler neck goes
yeah sunroof model.... where do the drain pipes run?
open the sunroof and all will be clear!
i got this problem too!! picked my girlfriend up n she started mouning it was wet!!! and i gotta sunroof too!! will try check this wkend then!!!
