Filler cap how to open, steering wheel how to adjust
Not sure if this is the right forum but here goes, just got a 2003 Polo, need to know how to open petrol filler cap, and how to adjust the steering wheel. thanks
  • Replies 10
  • Views 1.5k
Do you not have a manual with it ???? :S ????
No manual, hence my query in this forum.
should be a lever for the fuel cap usually around the drivers seat
and a lever around the steering column for the steering wheel
There is no lever around the driving seat for the filler cap, hence this post!
thought the filler cap just locked when the car is locked and u just pull it open from the outside when the car is unlocked
go to vag and buy a manual and ask then whilst you are there.
Edited by POLOMON
aye if your petrol cap ain't opening but your car is...it's the central locking, i had that problem, check the back right light..pull the pipe out that isn't electrical, blow down it..and your doors shall open, if thats the problem, go to scrappy replace the motor thing :)
Try pressing the fuel cap? My mums mk7 is on a popper thing you have to push in then it opens. Might only be on the mk7s though.
Not sure if this is the same but on my mk4, c/l didnt work so i had to stick my hand round in between two pannels on the right hand side of the boot, and basiclaly pull a little release thing. you are feel it n jus push or pull it slightly
Just bought a mk 6.Is in the workshop right now so not sure bout filler cap but steering adjustment is by way of a lever on the underside of the steering cowling(housing).Just pull it down and you can adjust the position of the wheel forwards/backwards and up/down!!!
