HOW DO I REMOVE MK3 SEATS?
Hey!
Never removed a set of seats in my life... How do I do it?
I've got a full GT interior waiting for my GT, but haven't looked into how to remove the old one...
Any help is appreciated :D
Thanks, Garner
  • Views 1.9k
Undo the 10mm nut and allen bolt on the front of the seat runners, remove the trim on the runners, and slide the seat all the way back. It just pops out.
and for the rear is just 2 bolts for the lower bench n 4 for the upright part.
Quick tip, if you're dealing with a tiltbase driver's seat. Tilt it all the way forwards before trying to fit it (prefereably before taking it out in the first place). It'll line up a lot easier. It's not the end of the world if you don't, but it'll save a couple of swears.
Edited by Yeti
Thanks... If I'm feeling better I'll have a go tomorrow (weather dependent also)
The back seats are screws (fuck knows why) and they always seem to be really really tight so make sure you use the right sized screw driver or you'll just make your life a misery if you round them off. Bit of WD-40 and a bashing with a hammer never hurt :D
Thanks for the info guys... Got 'em out
Funnily enough the rear seats were dead easy... I needed the WD40 for one of the front bolts though
Tomorrow=Clean GT interior and carpet, clean floorpan, clean dashboard etc and fit it all inc retro radio/cassette :D
O and I need to fix the passenger window seal :(
I always find it best to use a ratchet with a screwdriver end on the rear seat screws. You can push down on it and get a lot more leverage through it than with a normal screwdriver.
