Coupe back seats into saloon?
Like it says - can the Polo coupe (Mk2 or Mk3) rear seats be persuaded to fit into a Mk2 saloon?
  • Replies 9
  • Views 1.3k
I've heard of them being persuaded into a mk2. I've always though a rado bench would be interesting! Probably to wide though.
oo! a rado bench! that would be LUSH. , but I'm sure the coupe seats could be made to fit easily
The problem is presumably the back of the upright part - does anyone know if the metal part (which forms the floor when the seat is tilted forward) actually comes off?
no it doesn't come off (well, not without an angle grinder anyway). I'd have thought it would be pretty straight forward to bolt the coupe back panel to the saloon bulkhead anyway?
I believe corrado rear bench is actually too thin, leaves about an inch gap either side. I've not actualy tried it though, only ever had the corrado front seats in the GT I used to have (the rear bench never made it out of my loft till I sold it).
tbh i think an inch gap is live-withable for some mint leather rear seats? imho
An inch on either side doesn't sound like much. But if you put it in I can see it looking a bit rubbish.
I'd rather have a proper fit tbh. Just depends how much of a perfectionist you are!
yeah I've seen it done in mk1 golfs, there is just a bit of a gap on either side, which if the metal you can see through it is painted black it's hardly noticable.
Some confusion at this end - the Corrado rear seats will leave a gap, OK. Am I going to get a gap putting the standard Mk2/Mk3 coupe rears into a Mk2 saloon? Thanks for all the inf so far.........
AdamP did it, just swapped the back rest cushion over and tied it on iirc. HTH.
