Painting plastic interior
Right this summer I'd like to paint my dashboard a different colour, but smooth the surface at the same time. Do I sand down the surface to make it smooth? Then primer in plastic primer and paint over the top, and lacquer over the top that???
Is body lacquer and paint ok to use? Or do I need special shizzle?
Sorry for all the questions i'm shit at bodywork!
  • Views 1.6k
i woudlnt say sanding was such a good idea s i think the dashes are foam arent they so it woudl go all funny all i can think of really is plastic primer then high build or body filler sanded and sprayed with exterior paint.
the best way would be streth thin fleece material all over use fiberglass resin to make it hard then skim with filler sand smooth prime and paint not the easiest thing to do and probably best to remove it to do it
My mate sanded the dash inserts on his Rover then used primer and paint. Need to use primer before spray paints as they attack the finish on the plastic.
has anyone used interior car dye before? i need to do the plastic rear pillars and also the fabric on the inside roof!
any recommendations anyone?
anybody? you know that nasty grey plastic inside the car? well what paint etc can i use to dye it
thanks lads
