Rust in spare wheel well...
Hi,
I took the car apart today to give it a good clean and found some bubbling rust in the bottom of the spare wheel well. After a bit I'd made a nice big hole... so what's the best way to patch it up and would it be an MoT failure?
Cheers,
M
  • Views 1.2k
Think you can get away with filler on that if you dont know a cheap welder
it's not an MOT failure as it's not close to any suspension mounting points or anything but it will only get worse if left. The proper thing to do is to cut out all the rust till you are left with clean metal and then weld new plate in, then underseal and paint. But you could get away with fibreglassing it (P40 filler), just make sure you cut out all the rust though whatever you do.
