Opinions Needed
First off I appolagise if this is in the wrong section!
I drive an MK5 Polo and have recently put some 16 inch rims on it, although this has reduced the arch gap slightly...I'm still not happy.
The guy at the garage, the guy that fitted the alloys, other friends in the motor business have told me not to even consider putting coilovers or springs on my car as it will mess up a nice handling car.
So to those who have lowered their cars..is there any horror stories? Any reasons why you shouldn't lower?
Also...I am thinking about putting a rear spoiler on my car....is there any decent ones about?
I'd like one that means I can loose the rear light on my rear window and have one built into the spoiler itself.
Any help appreciated!
  • Replies 12
LOL @ Ruining Handling Comment! Coilovers would be the best thing to happen to your car for handling, I know before lowering mine it handled like a boat. Plus coilovers are adjustable height, and if you wish to spend a significant amount on a decent set up you can also adjust damping, to suit your ride preferences.
Regarding rear spoilers, Votex do one for the mk5, as well as a genuine VW GTi replica spoiler. Both cost around 100 quid, then paint and fitting on top.
If you buy cheap coilies you car will handle worse. Less compliance in the suspension/dodgy spring rates will mean your car will skip over bumps instead of soaking them up.
Which on potholed roads means poor handling and ride quality.
the only handeling issues I've have is the tyre to arch clearance but i guess you dont need to be stupidly low
the plus side, i have unbelieveable grip ask anyone that has seen my car going.
id recomend getting it lowered definately, i hated my car when i first got it and actually thought the handling was verging on dangerous! set of good collies sorted that out and hasnt put a foot wrong since :)
just make sure you get your tracking and camber done after.
With decent coilies you'll get better handling. I think what everyone means by handling is the comfort and not the handling. You'd deffo loose comfort as the suspensions much stiffer BUT the handling improve drasticly rather then a polo sitting on 16's at standard height.
The lower you go the worse the comfort gets. You have to examine the ground your driving over for potholes, cracks, dodgy drain covers, speed bumps etc. With cheap coilies the comfort is the same as everyone above has said before me.
Hmmm..the next issue is how low do I go and what coillies do I get?
I want to be noticebly lower but I am forever mounting Kerbs and going over rather large speed bumps, being able to mount kerbs at the last minute is kind of a bonus...one of which I don't want to loose!
That's the beauty of coilovers, you can adjust the height to whatever you want it to be. You can go as high as only a 30mm drop or as low as 120.
with coilies mounting kerbs is a no no!
First you got to chose how low you wanna go and if you'll always change the ride height. If your not then just a shocks/springs kit would be enough. if you want to go really n will adjust once in a while then coilies it is. Height is up to where you always drive ie if theres speed bumps n how high etc. For it to be as low as you want and nothing to scrub then it depends on rims, tyres and height.
Sorry but I'm sticking to my guns here. Good handling is NOT losing the body roll. A good handling road car will enable you to hammer along rutted country lanes soaking up potholes etc, something which cheap coilies will not do. A bad handling car (ie, -120mm on cheap coilovers) will skip over bumps in the road, sending you onto the other side of the road, it will be badly damped, the car will leave the ground over slight elevations etc and be very crashy. Not what you want on a road car.
If handling and daily use is a priority, then invest in some Eibach pro-line springs and matched uprated shocks, these will control most of the body roll, and enable your car to be composed on rougher roads, and due to the progressive winding of the springs, you will also get far better ride comfort, perhaps un-noticeable from standard!
You can get FK highsport coilovers for just under £400, and a mate fitted these to his mk5. They aren't the most expensive items and I'm sure there are better solutions out there, but they were a fantastic improvement. He ran about 70mm lower with 16's on and the ride was very comfortable, soaked up bumps and road surface changes with ease, while still making the car stick to the road and corner flat at pretty high speeds.
So i'd say go for some mid-range coilies, and see just how much better the car is to drive!
I get your point also, I don't mean decking a car would give you superior handling lol thats totally the wrong way of doing things. The handling depends on many things and what you get too. Mine can go around smooth corners quite fast and stick to the road quite well. However, I give up handling on streets where mine does skip on major potholes so I have to stay more alert. its dropped at 80mm which I thinks a bit excessive for handling giving way to looks.
I've got Highsports on the Golf and they ride really nice at about 80mm down, I have also wound them down to the bottom and the firmness is stupid, I could take the helper springs out to get a bit of a softer ride but I'd just destroy my tyres and subframe :lol:
I've stuck to 80mm and got the camber set up slightly negative at the front and it does drive very well. Uprated ARBs are perhaps my next step.
One other thing worth doing is polybushing the subframe and rear beam mounts, but sticking to brand new OEM bushes everywhere else.
what about thw philj coilies. are they any good?
