how hard would it be to smooth the plate recess on the front bumper
as above...i have a 6n and would like to fill the recess...whats involved and how hard would it be?
  • Replies 11
  • Views 1.8k
I've been wanting to do this for a while, i think you have to use a part of an old bumper plastis weled to fill the majority, and the filler for the rest anyone else got any input?
ITS FOR MY 8V RECESS BTW
Just a thought, but wouldnt you be able to use a plastic cement/Polystyrene cement. It has the same principle as plastic weadling but it's alot easier. Just apply the adhesive to the bits of plastic needing to be joined and as the cement contains a solvent that melts the surface of the plastic.
Over a period of time, depending on how much is applied the solvent would evaporate therefore resulting in both parts joining and the strength returning to the plastic as they are joined together. From there you would just go on as normal applying the filler and so on.
Would that be possible?, It could possibly be an idea to explore, maybe someone with a bit more expertise on the body work area could elaborate with the issues of plastic cement . However i will look into it!
Edited by polo_dude
I'm sure chrispy did that on his car, but his was a 16v front bumper
plastic welding.
get a similar bumper cut out a piece big enough to fit the recess then begin welding it to make it fit nicely. then you will need to sand it down to make sure the welding is smooth. then a skim of filler accuratley applied to get the job done.
hope that helps.
plastic welding.
hope that helps.
yeah do it as above if you want a decent long lasting finish! minimal filler if any at all is the difference between a good and bad job!
plastic welding.
hope that helps.
you don't want any thing smooth just leave it rough as it will allow the filler to get a better grip
the bodyshop that did mine, plastic welded, then fibreglassed over the top of that for strength, then filler to get the final shape. i can tell you the result is spot on and i've monted a kerb with it in ice and not so much as a crack showed up!
my was done with fibre glass. first off you need to rough up the area with a wire brush as it give it some thing to bond to. then slowly build it up layer by layer when you've got the shape you want you give it a light coat with filler to finish it off. don't use much filler though as it sinks over time.
apparently fiberglass will crack over time.
