n00b
Hey guys, hows it going?!!
not got a polo yet, but joined up here cus i 'm tryin to get a bitta advise on a 1.0 coupe malibu S, anything i should be wary about when lookin at this car?
cheers for any help :)
Ben
  • Replies 14
  • Views 890
hello
hey noob!
8-) welcome!
Lo nub. :-D
Mk2 Coupe or a Mk3 Coupe?
-N-
hello ben
hello noob
alreet n00b
welcome to clubpolo nOOB :)
alright guys,
I do believe that its the mk2 polo, round headights etc etc :)
lol leave the poor NOOB alone.
welcome to cp dude
welcome to the wonderful world of cp nooblette!
oooh oooh i have one of those. with mine the only problem with the body was rust around the filler cap and a bit under the arch trims..
Welcome to cp
Mk2...check for...
1) Rust in the battery tray, might need a metal plate welding if its rusted through.
2) Rust on your chassis, drivers side, behind the little storage area under the steering wheel. I had a huge crack, again easily solved by welding a metal plate. You'll know if its cracked because rain will come through.
3) Carburettor - open the lid off the air filter and get some carb cleaner (tin of spray @ £5) down its throat. Whilst the engine is warm, hold the revs at 3,000rpm and spray into the hole for a good 5-10 seconds. Someone on this forum reported back to me with a smoother idle.
4) Give it a basic service and your laughing. oil, air filter, spark plugs etc. Get a new coil as well...helps cure a lot of idle related issues.
Pennies dude pennies.
-N-
Edited by nick0323
morning bOOb
