Sunstrip
Simple question to all you out there with sunstrips - is it fitted to the inside or the outside?
Edited by Wiggy
  • Views 2k
most sunstrips that are of the vinyl type are fitted to the outside . you rouchly cut to size first . measuring up against window with more than overlap. then you clean the window good n propper ,
then u can do it a few different ways - a good one is to squirt a water and small ammount of fairy liquid mix - then remove backing off the sunstrip bit by bit , whilst placing it onto the windscreen . make sure that the strip is straight and where u want it . then u use a flat soft ish instrument to squeeze all airbubles out . centre to outside- lots of people use credit cards etc. wait to dry - whilst doing this trim edges tightly with a good blade .
I see. But will the windscreen wipers not damage the sunstrip? Or vice-versa?
mines stuck on the outside. bit its pretty shite so i'll be taking it off soon. The wiper does go over it, but does no damage to the strip or the wiper.
i THINK that if you have a sunstrip that the wipers pass over, it can fail an MOT (mines not been for a mot since it was fitted) as its deemed to be obscuring your vision. all down to the tester i spose.
aye it wont damage it , but some people say it will fail mot if the wipers go over it , sumut to do with where u normally view from??
window tint sunstrip..........goes on the inside and can c through it so it will pas a mot
Top tint on the work car's on the inside.
Better not to have one at all though.
id personally leave it on the inside...
of the packet, on the shelf, in the shop, as far away as possible from your car :lol: :lol: :lol: :lol:
